Devolo MicroLink dLan -sorry no pic`s
  • gonzo0815
    • Feb 2006
    • 1600
    I got a not working Devolo MicroLink dLan (it is a Powerline device) back from a friend, where i have installed it for a few years.
    It was one of the units with a 10Mb network connector.
    The problem was, that it was not reachable anymore, even the supplied config program could not find it.
    After a closer inspection i found a visible bulging 4700uF 10v (12,5x 25mm) cap as bypass capacitor in the linear PSU circuit.
    I replaced it with an 2200uF 16v Pansonic FM, as it was the closest match in size and value i had laying around.
    I tested it twice with only the 2200uF cap and with an additionally attached 2200uF UCC LXF without any difference.
    So i decided, that the 4700uF are not required and probably only to have plenty of reserve.
  • playit
    ccfl lcd laptop repair help, pics attached
    by playit
    this lcd first started showing green lines horizontal ,with flickrs then one day stopped showing rest of the screen , now it just like in the pic , i can see mouse at top,also the icons at right end of screen , i also tried to look around the cable wires ,adn loosened it ,but its the same result . i tried the flex test , the monitor changes to white ,and different colours, but dint show the actual picture , external monitor vga connection is good, so please guide me what next to do . please verify the pics, thank you ....
    03-15-2023, 05:08 AM
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
  • r2digital
    Boston Acoustic MSUB no sound output(pics)
    by r2digital
    The off/on/auto switch was busted so i forced it into auto mode and now the blue light comes on but i don’t get any audio output. Does anyone one have any experience repairing this amplifier? I looked it over, checked some the of output transistors, some of the power resistors and cleaned that nasty conductive epoxy glue stuff off but not having much luck in the trouble shooting department.
    I did however find a part of the PCB that was discolored from heat...
    03-22-2024, 06:00 PM
  • jimbofz
    upside down pics when posting?
    by jimbofz
    Hi everybody just wondered why when i post pics they end up upside down?
    i also tried rotating them so they were upside down when i posted them and they were still upside down confused?
    12-24-2021, 03:15 AM
  • digitalshooter
    Pics
    by digitalshooter
    08-02-2023, 12:11 PM
